Configure a PIM virtual neighbor if the next hop for a static route cannot run PIM, such as the Virtual Router Redundancy Protocol (VRRP) address on an adjacent device.
- Select PIM.
- Select the Virtual Neighbors tab.
- Select Insert.
- Specify the IP address of the virtual neighbor.
- Specify the interface index for the PIM interface.
- Select Insert.
Virtual Neighbors Field Descriptions
Use the descriptions in the following table to use the Virtual Neighbors tab.
| Name | Description |
| Address | Specifies the IP address of the neighbor. |
| IfIndex | Specifies the IP address of the PIM interface. |
